On hypermesh, when using a 0D spring element to model an elastic articulation between two pieces, it happens that the two pieces are always linked rigidly. It looks like the 0D spring element is not taken into account in the simulation.
I tried for example to set a very low stiffness in the PBUSH property. Then I created a 0D-element on node 99145, that is linked rigidly with each of the two pieces, with the PBUSH property. I also assigned a system.
I run the simulation, and on the modal analysis, the two pieces where still clamped to each other. ..
Does anyone have similar issue on that topic ?
Thanks
