Just noticed something that is troubling me.
When looking at Element Quality in 2025 version of HyperMesh/Optistruct, in the Criteria display, even though I have set the criteria in the Criteria Editor, the Iso plots in "Criteria" don't use the same Fail criteria. For example, in the image below, the aspect ratio Fail is set to 5.0, yet "Criteria" sets it as 1, and unsurprisingly, the fail count comes up as 100%. The QI Range display comes up OK as you see in the second screenshot below.
I did not have this problem in the 2024 version.
What am I doing wrong? Why are the ranges not in sync with the criteria editor?
thanks,
