Description: Oscillations and energy errors in my Radioss model
Product/Topic Name : Radioss 2025
Hi everyone,
I'm trying to model a knee prothesis in Altair Radioss
 I modelled it as represented below :
- The tibial implant is not represented
 - A rotation movement is applied to the femoral implant, around the Flexion extension axis
 - An antero-posterior force is applied to the Tibial insert, along X2 axix
 - A vertical force is applied on the tibial insert along z axis (this force always tend to keep contact between the femoral implant and the tibial insert)
 - A rotation torque is applied around the Z axis
Forces and displacements are applied on remote point, linked to the solids using rigid bodies.
The contact between the Femoral implant and the Tibial insert is a Type 7 contact
After running mu calculation, I got a 60% error. The Dt noda is quite low, but tif I increase it, I the have an important DM/M which is not acceptable either.
Does anyone have an idea from wher my problems could come from ?
Many thanks for your help !
