I have modelled pipe with Shell elements and coolant with tetra element .
I have to perform modal analysis .
I have used MAT10 property for fluid .
How to model the fluid pipe interaction . As the pipe system has horizontal and vertical pipes .
for modeling fluid-structure interaction in OS with fluid explicitly modeled you have to define ACMODL card .
You can also check out this article for more details:
Kind Regards
Alberto
