I have created a config file in a location that the personal
edition, 2025.0, of the Altair SLC should use, see below
C:\Users\roger\Documents\My WPS Files\altairslc_local.cfg
-WORK 'd:\wpswrk'
-set SASAUTOS ('!wpshome\sasmacro' 'c:/wpsoto')
-SASAUTOS (SASAUTOS)
-SASUSER 'd:/wpsusr'
Also tried setting an environment variable
ALTAIRSLC_CONFIG C Users\roger\Documents\My WPS Files\altairslc_local.cfg
They both failed
From proc options
WORK=C:\Users\Roger\AppData\Local\Temp\WPS Temporary Data_TD24984
The location of the WORK library
CONFIG=( 'C:\Program Files\Altair\SLC\2025\altairslc.cfg' )
Also having trouple setting the autoexec?
Please Help
Roger
