In 1D spring Creation, How to create a spring between two faces?
I used two methods,
1) Create a Rbe 2 in the two spring connecting surface, then directly create a spring by picking two center nodes of rbe's from the two surfaces.
2) Create a  center nodes just below the two spring connecting surfaces, then create a spring using those nodes. Then create a rbe2 for those surfaces by picking 1 face and spring connected nodes/
Which is right way to create spring elements?
Thanks.
