I am using TI's LaunchXL-F28069M eval board, I am running the TI DRV8305 PMSM InstaSPIN Lab11, and I am following the Simulation and Code Generation of TI InstaSpin Using DRV8305 Tutorial. On the eval board, CAN bus is exposed on J12. How do I add CAN bus to the .psimsch and configure the CAN so that I can control the motor externally from a separate controller?
Thank you,
