I can't read the .cntf file in the hypergraph after adding CICPS after request in the FEM file.
Please let me know if anyone faced similar issue and is there any solution for this?
Thanks,
AJ
Hi Ayyappa
*** .cntf file will be read in HyperGraph, also we can open in Tex Pad and see the values.
Could you share the file and cross check from our end and let you know.
Regards
Harish
Hi Harish Please find the attached cntf file.
Yes, we can see in text pad but if i want to plot in Hypergraph it should work right?
Normally itis working but after adding CICPS, it's not working.
Please let me know
Thanks for sharing the files, its also not opening in our system.
Could you share the input file?
I cant share the input file here, but I have given below Output request.
CONTF(OPTI,CICPS)=ALL
Without CICPS in the above command i can open in Hypergraph. but after adding CICPS i am not able to open the same in hypergraph.
Hi please find the sample file in which we contact file will be generated and that can read in HyperGraph.
Could you run and check the files and setting.
Hi.. Harish
Did you run in hyper mesh latest version 2025.1
CICPS available in only 2025.1.
Hi
I ran in older version which was working fine, let me check in latest version.
Yes, we ran the model in Ver 2025.1 and cntf file file gerarated . but it opening in HG.
We will invetsage and let you know.
Okay..
My aim is to plot CICPS values over the time increment.
