Hi ,
I am currently performing a Conjugate Heat Transfer (CHT) analysis (steady-state) using SIMLAB and AcuSolve. The MRF (Multiple Reference Frame) RPM is approximately 20,000, and my CAD model includes a universal motor. Based on this, I estimated the heat source to be around 900 W.
I used a CFD mesh for both the fluid and solid domains, with six boundary layers and a surface mesh fraction of 0.1. The boundary layer mesh type is set to tetra.
After setting up the boundary conditions, I solved the model and reviewed the results. The temperature in the body where the heat source is applied reached 600°C, which is much higher than expected. I then reduced the number of boundary layers to four and ran the simulation again. This time, the temperature in the same region was around 100°C.
This significant difference has left me unsure about how to correctly choose the number of boundary layers.
In simpler cases, such as external flow over a flat plate or internal flow through pipe-like structures, there are standard methods for calculating boundary layer thickness and the first layer height. However, for my current case, I’m unsure how to determine the appropriate boundary layer setup.
Could you please advise on how to select the boundary layer configuration for this type of simulation?
Thanks & Regards,
Siva.
