Hello everyone,
As I have trouble when importing PDF reports in Monarch (data is distributed totally different from the way it is distributed in the actual PDF, thanks(not) to the software which created that PDF file) I was wondering which is the best way to re write the content of a pdf in order to get a clean import in Monarch and to have the data distributed in report design exactly the same way you can see it in Adobe.
I was thinking of saving the original PDF as JPEG, in order to somehow flatten the data, then to use some OCR method ( maybe again with Adobe) and transform the JPGS to text, and ideally to make it retain the same distribution of the data on each page as in the original PDF.
The above I will try asap, but meanwhile, is there someone who had this frustrating issue and found a better solution to this. For me an my team this could be a breakthrough which we would pay in tons of beer via dhlexpress : )
Have a nice weekend all, and thank you in advance for any suggestion given.
Radu
