Difference between windows bat run simlab scripts VS simlab GUI “automation-scripting-play-auto”
Hello everyone:
I have a question about excuting simlab scripts.
when i run scripts by GUI “automation-scripting-play-auto”,i can get nice inp file,but when i run the same script using bat command, the output file have many differences against GUI, my bat command is "call 'c:\program file\Altair\Simlab\bin\win64\Simlab.bat'"
and i run the same scripts many times ,it outputs different size inp files, i check the file using hyperworks.
i run scripts by GUI many times ,it output the same size file.
so my question is what is the different between bat excution an gui? how can i get the same inp as GUI method?
Thank you very much!
1 - 1 of
11
Can you please provide more information? If you can share your script would be more helpful. Thank you!
Kind regards,
Marc Steiger
