I am trying to verify different sizes (infinity x infinity, 16 x infinity, 16 x 16) of the referenced Dual-Polarized Planar Ultrawideband Modular Antenna Array [1]. I have created a simplified parametric model of the Unit Cell (attached herewith) in FEKO.
Instead of modeling the connectors and energizing using waveguide port, i have used simple wire ports with the required radius during meshing. Small cylinders, instead of wires, were created between the middle thin dielectric layer to avoid small segment errors (Error 116: The ratio of the segment radius to length is too large).
- After creating a uniform array, say 16x16, the model is taking awfully long time to even open, leave aside simulating. Spacing of 6.6 mm (Model parameters SpacingX and SpacingY) is used in both X and Y directions. The 16x16 model is too big to be attached here. Can the unit cell be simplified any further? Tried using MLFMM as well (ERROR 55723: It is highly recommended to use the conventional MoM, since the MLFMM near field matrix fill exceeds 20% of the full MoM matrix).
- Machine details. Windows 10 PRO OS, i7, 32 GB RAM.
- 3x3 array with discrete frequencies is taking prohibitively long amount of time. Sum of the CPU-times of all processes: 250336.552 seconds ( 69.538 hours)
. On average per process: 31292.069 seconds ( 8.692 hours) - How to simulate an infinity x infinity array using the same unit cell?
[1] Holland, Steven S., Daniel H. Schaubert, and Marinos N. Vouvakis. “A 7–21 GHz Dual-Polarized Planar Ultrawideband Modular Antenna (PUMA) Array.” IEEE Transactions on Antennas and Propagation 60, no. 10 (October 2012): 4589–4600.
https://doi.org/10.1109/TAP.2012.2207321
Warm regards,
Asif Rizwan
