Description: [I am simulating the cooling of battery pack in a battery bucket using airflow coming from an axial fan which is attached to the battery bucket. I am using the Multiple Reference Frame(MRF) method where the axial fan is kept stationary and a cylinder which covers the fan is given a rotational velocity. The air enters the cylinder inlet and exits the battery bucket through a number of outlets after it passes over the battery pack. I want to obtain the operating point of the axial fan on the fan curve of the axial fan( operating point is the intersection of the system curve and the fan curve).I have given inlet static pressure of 0 Pa and outlet static pressure of 0 Pa. After solving, I should get the static pressure difference and the volume flow rate in the fan curve which will give me the operating point. But I am not getting the operating point after solving. Please give me alternatives. ]
Product/Topic Name : [Altair Simlab 2025 ]
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
