Random response Analysis RANDPS
User: "ManishKanwal"
Altair Community Member
Hello all ,
I am performing a Random response analysis and I have a question regarding the keyword RANDPS. What does J & K represent there?
Does K represents the PSD at the source of vibration and J represents the PSD where the vibration is measured?
Thanks!
1 - 1 of 11
    User: "solon"
    The RANDPS card defines the load set power spectral density factors for use in random analysis having the frequency dependent form : Sjk(Ω)=(X+iY)G(Ω). The J and K entries determine whether the PSD is of auto correlation or cross correlation function and X and Y entries are the components of complex numbers, which means they are the real and imaginary parts and usually represent Cross-Spectrum PSD.
    For auto spectral density / Uncoupled PSDF, J = K, scaling from real-valued X will be greater than zero and Y must be equal to zero.
    For cross spectral density / Coupled PSDF (input from 2 sources), J will not be equal to K, and both X and Y can be specified. The Cross-PSD will be a product of a frequency-independent complex value (X+iY) and a frequency-dependent scalar function (G).
