Earlier this week, I had some problems with the student license (I was getting error -40 I believe), so I deactivated the license and activated again. Now I was able to use PSIM again, but I was getting new errors with a program I knew it had worked before. So I checked the license setup and noticed I did not had all 4 features activated, and I could not change the active features.
I uninstall and install PSIM again, and deactivated once again the license, but I still couldn't change the features. What can I do?
 Note: Researching here, I found out that Code Gen is not part of the Student License, and that you cannot change the features. But I know for a fact that when I first install PSIM I had all 4 features active. Could it be that I was using the free trial when I first install it?
