Hi Good day,
I am currently working on a CFD analysis of a cylinder and piston assembly, using the AcuSolve Ideal Gas Compression in an Actuating Piston tutorial from SimLab as a reference.
Following the tutorial, I have created the fluid domain and generated a table that defines the piston motion based on a mathematical equation. I plan to apply this motion as a translational mesh motion in the simulation.
Could someone please explain the steps shown in the image above?
Specifically, under the Nodes section:
- Mesh Y-Displacement
 - Type: Linear
 - Mesh Motion: Piston
 - Curve Fit Variable: Y Reference Coordinate
 - X1: 10.0 m
 - Y1: 1.0 m
 - Y2: 0.0 m
What do these terms represent? Why is X1 set to 10.0 and Y1 to 1.0?
Thanks & Regards,
Sivaprakash.
