Automatic export text file about Model Information
User: "Jammanman"
Overview:
The script automatically extracts model information (e.g., material, mesh type, mesh count).
If the model is not suitable for analysis, it will notify you of any missing or incomplete data. This allows you to verify both the model details and any potential errors.
You can also use this simplified information when sharing the model.
1. Open your model file
2. Load script file(.*tcl) (The script file is attached to this article)
3. Check the export option
You can select the desired options and export just the information you need.
4. Select the components which you need the Information
(If you selected "Displayed Components" Option, skip this step.)
5. Set the file save path & Check the Export file
The text file will inform you if any component is missing a property or if any property is missing a material.
Comments
No comments on this post.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
