Using Monarch (v13.5). When I export to .accdb I noticed that multiple .MDF & .LDF files are being created in App Data\Local\Temp folder.
For example, today I exported two outputs from Monarch to one Access Database.  When I checked the Temp folder there were 12 MDF/LDF files toaling 440MB.   After closing the Monarch program, if I try to immediately delete any of these TEMP files I get this message:  "File In Use. The action can’t be completed because the file is open in SQL Server Windows NT – 64 Bit. Close the file and try again."
Before I contact my IT support, I thought I would ask the Monarch forum -- is this creation of temp files a 'normal' behavior for Monarch?  Any insights would be appreciated.  Thanks in advance.
