Hi
I am trying to model a pin-loaded test of composites under high-speed loading with Radioss. I used MATLAW25 and Hashin failure criteria to capture progressive damage. However, after an initial peak in the load, my resultant reaction forces fall to almost 0 instantly, then increase again to a lower peak and then fall back to 0. But for crushing the force while oscillating, it should gradually decrease to 0. I'm not sure why this is not happening in my model. I have attached the files to this. Any help on this would be greatly appreciated.
