How is the tangential slip distance calculated in the archard wear model? Was it extracted from the contact model? Hope to get a detailed answer, thank you
You can see the Archard Wear code here:
https://community.altair.com/community?id=altair_file_exchange_article_view&sysparm_article=KB0122123
// Get normal force double normalForce = contactResults.normalForce.length(); // Calculate tangential displacement double tangDisp = relVel_t.length() * timeStepData.timeStep; // Calculate wear volume double wearVol = wearConstant * normalForce * tangDisp;
The normalForce is passed to the Archard model from the base physics model chosen. The tangential displacement is calculated per time-step based just on the relative tangential velocity of the two elements in contact.
Regards
Stephen
