Description:
I installed Operator Toolbox v2.18 and Rapid Miner v9.10 refuses to launch in normal mode, and only works in safe mode. I get a variety of error messages with different reasons. I uninstalled and reinstalled RM and extensions, all the same. I thought it was a problem with java compatibility and tried running it on my MacOS (latest java) and older Windows (no java) and still get exactly the same problem after I install the Operator Toolbox v2.18.
Product/Topic Name : Problem: Operator toolkit v2.18 extension, once installed, it prevents Rapid Miner v9.10 from loading in normal mode, safe mode only with all extensions disabled.
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
