Artificial Intelligence is being increasingly applied in engineering to streamline processes while maintaining precision. As we move towards to electrification, it's crucial to find efficient solutions for simulating multiple voltage converters. Artificial intelligence can help us achieve this by significantly reducing simulation time while maintaining accuracy. Therefore, we attempted to simulate a DC/AC converter using romAI, with the intention of replacing PSIM converter models. RomAI will map the d-axis & q-axis current of the dc/ac converter. The schematic we are trying to replace with the romAI block is the following:
So, in this article, we will explore a step-by-step methodology for training a neural network using RomAI.
Step 1: Data Generation
To train a neural network, it is essential to generate or acquire appropriate training data. One effective method for creating training data is utilizing Hyperstudy, particularly when generating data from other software such as PSIM, Simlab, Feko, etc. If you are unfamiliar with Hyperstudy, you may refer to this article to understand its advantages over manual data creation through scripting.
Once the data is generated, it is stored in various folders and divided into multiple CSV files. To consolidate these files, use the provided 'Find_n_Copy.oml' script to copy all CSV files into a single directory. Subsequently, execute the 'romAI_data_append.oml' script to merge all the files.
When generating training data, it is crucial to avoid including unnecessary variables and data, as this can complicate the processing and significantly slow down the system.
Step 2: Pre-processing
To train a neural network using the RomAI tool, begin by opening the Twin Activate Software. Navigate to the "Tools" tab, where you will find the RomAI Director.
A separate window will appear, and within the "Pre-Processor" tab, you can import your training data.
Load the data into the Pre-Processor tab. If you intend to train a dynamic system, ensure that the data is appropriately filtered. You can apply a filter from inside the romAI Director.
As illustrated, the filtered waveform (green) is smoother than the original waveform. In this example, the cut-off frequency is set at 5kHz, though this value may vary depending on your specific system. It is advisable to experiment with different values to observe the results at the conclusion of the training process. Once you have selected all the relevant and filtered data, click on the "Export to Builder" button.
Step 3: Neural Network Setup
In the Builder tab, you can configure the hidden layers, the number of neurons per hidden layer, the number of epochs, and the test split ratio. If you are uncertain about the optimal settings, RomAI offers an auto-exploration feature. This feature trains multiple neural networks with varying numbers of hidden layers and neurons per hidden layer to help you determine the best configuration.
If you have not experienced with neural networks before, you can attend a course here.
Furthermore, at the Advanced Settings tab, there is a variable named Regularization Coefficient and it refers to the regularization term on the objective function. This helps avoid overfitting and might improve generalization. Due to the nature of Power Electronics systems, it is recommended to set this variable equal to 1e-6
Before initiating the training process, it is advisable to assign a meaningful name to the neural network that reflects the chosen parameters. For instance, you might name a neural network "Iq_prediction_epochs_100_TSR_0_2." This naming convention allows you to easily recall that the network was trained with 100 epochs and a test split ratio of 0.2. You do not need to worry about specifying the number of hidden layers and neurons, as RomAI automatically appends this information to the defined name, resulting in a name like "Iq_prediction_100_epochs_TSR_0_2_relu_30_30."
Step 4: Post-Processing
In post-processing, it is important to evaluate what makes one neural network superior to another. Two key metrics that indicate the reliability of a predictive model and its ability to forecast a waveform similar to the actual data are:
- Average Root Mean Square Error (Avg RMSE)
- Test Loss
Both metrics should be minimized as much as possible. It is important to note that these values should not be compared across different systems. Comparisons should only be made within the same system but with varying parameters.
Regardless of the values of these variables, it is essential to verify the predicted waveform against the actual waveform. This can be done by selecting the "Time Simulation" radio button.
Step 5: Twin Activate Deployment
A unique feature of romAI is that it can be deployed in a 1D simulation environment. After completing the training, we can insert a romAI block in Twin Activate model from the Palette Browser
Drag and drop the block into the model. By clicking on the block, you will need to load the folder containing the neural network you have just trained.
Once you click OK, all the inputs and outputs will appear. You can then connect them with signals and scopes, as well as integrate them with other models (e.g., PSIM, Simlab).
For more tips & tricks you can read some relative articles at the links below:
romAI Tips & Tricks for Beginners
Accelerating Battery Charging Simulations with Altair romAI - Part 1
