I need to use the thermal profile of a Mold created by Inspire mold in Simlab to use it as heat source for my simulations and testing of differents cooling systems. Is that possible?
I do not know if Inspire Mold can export results to SL directly. Unlikely is my guess.
If Inspire Mold can export the temperature profile as text file: x,y,z,temperature
Then SimLab could import it and provide is as thermal BC for AcuSolve. Regarding, heat source it is going to be tricky.
Might be worth to login to create Altair support ticket and get some official answer, as this is not an out of box solution.
