I use optistruct to optimize a model, it stops at the 9th step and doesn't finish this job. The solver displays following information:
The amount of memory allocated for the run is 800 MB. This run will use in-core processing in the solver. MUMPS solver will allocate memory separately and may run in different core (in/out) mode. INFEASIBLE DESIGN (AT LEAST ONE CONSTRAINT VIOLATED).
what dose it mean? How to solve this problem?
