using JKR v2 and Hertz mindlin API simultaniously
satri
satri Altair Community Member
Hello
I am trying to use the JKRv2 model as the inbuilt contact model for particle to geometry interaction and i would like to use the Hertz-Mindlin CUDA version as i want to manuplate some custom properties. Please tell me if it is possible to do so?
If so how? When ever i being in HertzMindlin API i keep getting this message
I done mind having in built JKR model. I only want the hertz mindlin CUDA version to manuplate some custom properties. Can i remove all the lines where the normal force is updated so on in the API and will it work? please let me know
Best Answer
  • satri
    Answer ✓
    I found sol I should do this
    I dont know how to delete this post. i found sol
  • satri
    I see this in one of the examples
    For the liquid bridge model, you have Hz-Md and LiqBridge Mdl running simultaneously.
    One difference I found in the code is this (in Liq Bridge mdl)
    Even if i include this in my Hz-Md cuda API it does not work. Is there anything else that i need to change? Please let me know.
  • satri
    Answer ✓
Welcome!
Welcome!
