Hi everyone,
right now i'm trying to simulate torque based on the dq current of a pmsm with inner rotor and 3ph. so far i have done it in flux motor and exported it into flux. However, i do not know how to plot or control the torque depending on the dq current as the parameter is not there. Should i use macros or just simply create it? if so, which one should i use?
Thank you in advance.
