I have a question regarding the proper CONTACT setup for modeling surfaces that are fully bonded with no initial gap.
In previous cases, I was advised to include a small clearance (e.g., 0.01 mm) between components to avoid convergence issues due to nodes being too close. However, in my current model, the physical assembly involves surfaces that are perfectly in contact, so introducing such a gap does not accurately reflect the actual condition.
Currently, I am using CONTACT with the type set to FREEZE, and the ADJUST parameter set to AUTO.
However, the 0.01 mm gap remains throughout the analysis and is not automatically closed, even with the ADJUST=AUTO setting enabled.
Could you please advise on the correct way to model this situation in OptiStruct?
I would like the surfaces to behave as if they are fully bonded or welded — with no gap and no relative motion — while also ensuring numerical stability during the simulation.
