I'm working on a project involving a synchronous machine in flux 2D and I need help understanding how to generate flux maps. I want to generate these flux maps based on the input currents (Iabc) and the rotor speed. But, I would like to avoid using the dq transformation in the calcul .
it is possible to extract directly the Flux in the phase a, b and c using sensors.
To create a new sensors you can use the menu advanced → Sensor → New in the predefined sensors yu can find sensor of type magnetic flux, here you can chose a coil conductor region. Then you will have the Flux in the three phases, then you can do your own operation on these Flux.
I hope this helps.
Best regards
Cyril
