Driving a vehicle over sand dunes is called as sand bashing and it is also known as dune bashing.
Sand bashing helps to:
- Predict the impact forces
- Obtain the body deformation
- Understand the skid plate wear
- Access structural strength
Simulation Methodology:
Sand bashing is carried out using three methodologies such as:
Case-1: EDEM+ MotionSolve:
- EDEM is used to model sand and MotionSolve is used to model the 4-wheeler with vehicle motion
- Vehicle chosen as a rigid body
Case-2: EDEM+ MotionSolve (Deformable Body):
- Sand impact force is obtained as an output
- Hood and Skid plate modeled as deformable bodies
Case-3: EDEM+ OptiStruct:
- EDEM is used to model sand and OptiStruct is used to model bumper and hood assembly
- Bumper and hood modeled as deformable bodies
EDEM Simulation Setup:
Case-1: EDEM+ MotionSolve (Rigid Body) Simulation Setup:
Case-2: EDEM+ MotionSolve (Deformable Body) Simulation Setup:
Case-3: EDEM+ OptiStruct Simulation Setup:
Case-1: EDEM+ MotionSolve (Rigid Body) Simulation: Results
Case-2: EDEM+ MotionSolve (Deformable Body) Simulation: Results
Case-3: EDEM+ OptiStruct Simulation: Results
Fatigue and Wear Analysis:
Summary:
Altair EDEM+ MotionSolve and EDEM+ OS simulation for sand bashing allows:
- Model various sand beds and piles quickly and easily
- Obtain the vehicle impact force
- Explore the wear of skid plate, bumper and hood
- Analyze how the loads due to different materials impact on the design performance
- Reduce dependency on physical prototyping and in turn reduces overall design cycle time
- Study the stresses experienced by structural member to optimize the design
Simulation Files:
CAD Files:
Sand Bashing- EDEM + MotionSolve Rigid body:
Sand Bashing- EDEM + MotionSolve Deformable Body:
The file size is >100MB, so if you would like the file, leave a comment below and and you will be contacted directly.
Sand Bashing- OptiStruct:
If you are looking for further information on EDEM or other Altair products we have plenty more on the Altair Community:
