I'm trying to model a vehicle in hover and cannot get the solution to converge. If you could shed some light on why the solution is not converging, it would help a lot.
What I have tried:
- Tried a single propeller without ground (viscous and inviscid) and it works.
- Tried two propellers and without ground, and it still works (both viscous and inviscid)
- As soon as I add the ground, it does not converge.
- I have tried varying the mesh size.
- I have tried converging the inviscid first and then the viscous.
- I have tried adding the ground to the excluded boundaries list.
- I have tried limiting the wake to 1 revolution.
- Played with the stabilization strength.
- Modelled ground in different ways.
None of the solutions seem to work. I have attached the simulation file for more info.
Question 2) I have added two propellers because I do not understand why there is a difference in pressure contours between the two propellers as they are essentially the same propellers spinning in different directions.
Thanks
