Hello everyone,
I am currently facing difficulties while performing a simulation of a typical near-field planar characterization. Particularly, I am considering the case of a rectangular horn antenna using an Open-Head WG as the probe. Here's a detailed description of my setup and the issues I'm encountering:
- I have created 3D models of both the horn antenna and the probe.
- I developed a macro that requests the SParameters to consider S21 or S12 as the open-circuit voltage measured in an anechoic chamber.
- Through the macro, the simulation process involves:
- Running the simulation for a given probe position to get the SParameters.
- Moving the probe to the next measurement point.
- Re-running the simulation to obtain the updated SParameters.
- This process enables me to perform a scan over a planar grid (as for a standard uniform half a wavelength field sampling) getting as many .s2p files as the points of the grid.
- High Computation Time:
- The simulation is computationally expensive because it generates a new mesh for each acquisition point.
- This occurs despite using a GPU and attempting to optimize the process with the MLFMM (Multilevel Fast Multipole Method).
- Noisy Results:
- The results obtained within reasonable computation times (<3 minutes per point) are noisy.
- Levels at -30 dB compared to the peak of S21 or S12 are highly oscillatory and asymmetric concerning the center of the scanning domain.
Is there a way to reduce computation time and improve the accuracy of the results? Any suggestions or alternative approaches would be greatly appreciated.
Thank you in advance for your help!
Product/Topic Name : FEKO, CADFEKO
