I have an issue where FlightStream 2025 crashes every time I run an unsteady simulation. I did not have this issue with the 2023 version. I have a Windows machine with 64gb of RAM and 32 parallel threads. I have tried running the same simulation on a Linux machine and it works fine. I have tried uninstalling and re-installing, but it has not fixed the issue. I have also tried running the 2024 version and it crashes as well.
Is there a way I can fix this issue?
Thanks
Edit: It only crashes if I go beyond 10 parallel threads. I monitored my CPU and it's not being used more than 30% (occasionally jumps to 50%).
I performed a couple of stress tests on the machine at full capacity, and they work fine..
