When using simlab, how to set optistruct solver to use gpu
Make sure your solution type can be run with gpu. Reference here: https://help.altair.com/hwsolvers/os/topics/solvers/os/optistruct_gpu_r.htm?zoom_highlight=gpu
If so, under the Format and Execute Options. You can put as additional the argument "-gpu". Like this:
In the out file you should get a notification:
Hope this helps.
Kind regards,
Marc Steiger
yes, it worked, thanks.
