I am performing a CFD Analysis of Air blower using SIMLAB to find the Flow rate of it.
I have done my meshing. But I have some doubt in Boundary and its size.
For Air blower model, How to choose the Boundary layer thickness and first layer height.
If I choose Y+ based, I am having HM CFD, Y+ calculator is there. In Y+ based, What I consider as Desired Y+ value and Reference length.
Which one should I take Air blower Inlet diameter or blade length of impeller as reference length and Y+ value?
Else Is there any method to find these layers values?
Thanks & Regards,
Sivaprakash.
