Dear Altair Community,
I am encountering an issue when trying to import CAD files into EDEM v2022.3. The loading bar gets stuck at 2%, preventing the import from completing. However, the same CAD file imports smoothly in EDEM v2024.1.
I have tried several troubleshooting steps, such as changing the file location to a shorter path, but the issue persists.
I have attached two files to this post for reference. Could you please advise on how to successfully import them in EDEM v2022.3? I need to use this version because I am coupling EDEM with HyperStudy, and it seems that only v2022.3 works well with my EDEMPy post-processing script.
I appreciate any suggestions or insights you may have.
Best regards,
Jipei
