I'm having an issue with SimLab 2024.1 where I cannot use Face Groups to define the Guide faces and Limit faces in the Select Adjacent Layers tool.
I can click on faces on the model normally which works however when I try to add a Face Group nothing shows up. Is this intended behaviour and is there a work around for an automation pipeline?
Will it work if I manually edit the python script to reference the Face Groups instead of the face IDs?
