I am using FEKO and have encountered a problem.
When I open CADFEKO and click 'Create a new project,' an error message appears.
(See attached image)
How can I resolve this?
박정우, the development is looking into this.
Hi @박정우,
Which version of Feko are you using?
Zeina
Thank you for your answer. I'm using 2024.1 version of FEKO. @Zeina
@박정우, thanks. Is this intermittent, or does it occurre at each time you try to open a new project?
It occurs every time I try to open a new project. @Zeina
As a last resort, I'm even considering formatting my laptop, but I'm not entirely sure if that's the right solution, so I haven't tried it yet.
박정우, I will investigate this further. Can you provide me with you Operating system and graphics card info?
@Zeina I'm using Windows 10 64-bit, and GTX 1050 Ti.
@Zeina Are there any updates from the development team?
Hi 박정우,
Can you please update your installation to v.2025 and check if you still experience the same behavior? Some improvements might have fixed this.
Best Regards,
@Zeina I updated my installation to v.2025, but the same problem still occurs.
Thank you.
Thank you 박정우 for your feedback.
I have shared this update with the dev. Will get back to you.
@Zeina Thank you!
You are welcome, I hope we will manage to solve this for you quickly.
