Hi, I'm studying electromagnetic analysis of motors using FLUX.
According to my studies, an electric field should exist if the magnetic flux density changes over time (based on the Maxwell-Faraday principle).
However, as shown here, there is no electric field, even though the magnetic flux density changes over time due to the rotor's rotation. (I have already exported the node values, and there is no electric field value present either.)
Additionally, I have another problem. I understand that current density can be calculated using the formula J=I/AJ = I/AJ=I/A.I calculated it manually, but the results are different from the FEM results. Even after adjusting the depth to account for discrepancies, the values decreased but the residuals between the FEM results and the theoretical results are still too large.
Is there any additional formula or factor I might be missing?
These are the two questions I want to ask. If you know the answers, I would greatly appreciate your help. Thank you!
