Hi everyone!
I'm working on a project about designing a model (QSAR - model) using Deep learning and in the "Deep learning" report i dont see the relation between the parameters and PIC50. Please help me
Thank you.
Hi @annata,
Kindly let us know which product is being used for creating the Deep Learning model.
The detail is required to direct the query to the required support team.
Many thanks.
Kind Regards
Garima Singh
Hi Garima_Singh
Thank you for relplying my post, I'm using rapidminer 9.10 for creating Deep learning model
Thank you for the response.
Hi @RolandJones, kindly support the user on the Rapidminer query.
Hi @annata
Thank you for your query, it sounds like an interesting use case! Just to confirm, you're predicting the PIC50 values using a Deep Learning model, and you'd like to extract more details on the relationship between the input variables and the predicted values?
Best,
Roland
Hi RolandJones
Yes, that's exactly what I meant.
Many thanks
Thuy an
Given you are predicting a numerical value, I think the Interpretation extension might be a good option here. For example, you can use the "Generate Interpretation" operator to assess the global weights of the model, as well as the absolute local weights.
Please let me know if you need any help implementing this.
Hi @RolandJones
When installing "Interpretation" extension, I get this error. Do you know how to solve it?
Thanks,
Thuy An
Could you please share the rapidminer-studio.log file to help diagnose the issue? On Windows, it can be found in %USERPROFILE%\.RapidMiner\rapidminer-studio.log
Is it the file you need ?
Many thanks,
Hi Thuy an,
Thank you, yes this is what I needed. My apologies, it appears that v0.8.0 of the extension is incompatible with your version of RapidMiner (now AI) Studio - I will raise this with development. You will need to install version v0.7.1 of the extension manually. To do this, please go to https://marketplace.rapidminer.com/UpdateServer/faces/download.xhtml?productId=rmx_interpretation&platform=ANY&version=0.7.1. to download the .jar file. You will then need to place this is in the %USERPROFILE%\.RapidMiner\extensions folder and restart the program. The extension should now work.
It's very kind of you to help me.
You're most welcome, if there's anything else that comes up I would be glad to help.
There is one more problem I hope you can show me how to deal with. Well, as you know, I'm creating a deeplearning model and I wonder that how can I save the Deeplearning model?.
To make it more clear, the purpose of my study is about predicting bioactivity of a compound. So, I need a model to predict bioactivity of a data that including compounds.
Like you know, in DL we'll get different results on different runs and I just want to save the best model giving the best result.
I don't know how to save the model, just know how to save the process that generate the model.
Hi Thuy An,
You can add a "Store" operator and connect the model to store the model in the repository for use later.
You've helped so much. I'm so gratefull <3
It's been a long time
I just have a question for you: "Is there any possible way to send a model from my laptop to another laptop?"
Hope you'll answer my quest
When the model is stored in the repository, it is also saved in the local file system, and can then be shared by your preferred method e.g. via email. You can find it by right-clicking and selecting the option shown:
Hope this makes sense.
P.S. please start a new community thread for new questions in the future, so other members can find helpful content easily
hi @RolandJones
That help me so much. I'll start a new community for the next question.
Wish you all the best,
