Dear Experts,
I was trying to get the simulation result of the protected model with some mechanical components. I imported the protected model and the geometry. I added standard configurations and S parameter configuration. If I put 2 or more frequencies (with "List of discrete points") in the configurations, the results are getting on just 0Hz. We can not see other frequency information in the results. The results come true if I put just one frequency in the configurations. Also, in the S parameter configuration, I tried to put 2 frequencies with "List of discrete points" but the result came with just 0Hz. If I put just 1 or with "Linearly spaced discrete points", the result came true. Is there a possibility it is a bug or are we missing some details?
Can you help?
Feko version: 2024.1
Best Regards,
