The Generate Attributes operator in Altair Rapidminer (AI Studio) does not seem to work to create a new attribute based on boolen check. I have attached a sample process and data. Can someone please confirm this and is this being fixed? I am using AI Studio version 2024.1.0.
Hi @amit_deokar,
You need to enclose the TRUE value in your expression in quotes, i.e.
This is because VarA is classed as a binominal variable, so the quotes declare that the "TRUE" value is some sort of nominal value.
Hope this helps. Best,
Roland
