How to use scripts to create gauge pressure monitoring points in hypermesh_radioss solver? gauge The type of the pressure monitoring point is Node definition and the node ID is used to select the pressure monitoring point.
Do you want to script? Or just create them? They are under SENSORS in HM:
Tip: If you can't find how to make a card, you can easily search in top right corner: (that's how I found the card!)
Dear Paul, Thank you very much for your reply, I would like to use the script. Because I have many monitoring points to set up, it is more convenient to use the script. Can you provide this script?
