Hello experts,
I've been running a large number of simulations in SimLab and need to export the AcuProbe results for each one. Currently, I have to open the log of each simulation and manually export the results, which takes me around 2 hours or more just for this task.
Here you can see a folder showing a quarter of the simulations I'm working on:
Also, when I use AcuProbe to export a variable, I do it manually for each simulation:
My question is: Is there a way to more easily export the AcuProbe results from multiple simulations?
The results I get directly from SimLab responses aren't helpful because I can only obtain the maximum or minimum value of the variable I need.
Additionally, I'd like to know what kind of results AcuProbe provides. Are they averages over all the elements of the surface or another type of result?
I believe that the results provided by AcuProbe are averages, because when I compare the results in SimLab with Query Results, and export the data and find the average of that variable in Excel, the results are very similar although not equal. I just want to be sure about what type of results they are.
I would greatly appreciate any help or suggestions!
