I am encountering an issue while performing an EDEM-Fluent coupling simulation. EDEM shuts down automatically and Fluent provides the following error message:
The fl process could not be started.
I have used Particle Replacement API and save the input.dem. The API 3 files also locate in the same folder but after some simulations the EDEM showed message that the plug in factory tried to create the particle of type that does not exist. I am using EDEM 2022.1
Thank you
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 83680 RUNNING AT Sam
= EXIT STATUS: -1 (ffffffff)===================================================================================
= RANK 1 PID 85612 RUNNING AT Sam
= RANK 2 PID 83240 RUNNING AT Sam
= RANK 3 PID 81412 RUNNING AT Sam
= RANK 4 PID 85900 RUNNING AT Sam
= RANK 5 PID 88020 RUNNING AT Sam
