Generative design exploration
Hi @georgetrik,
Thank you for providing additional details related to the Design Explorer Generative Design query.
We are checking with the development team on the same & will provide a suggestion for the same in the due course.
Kind Regards
Garima Singh
Good evening @Garima_Singh ,
Can you please provide me more information about the course mentioned?
Thank you in advance
Hi @georgetrik,
As per the Design Explorer development team, you may not be having the required EDS license feature as you have a student HyperWorks license/account & hence, the 'Concepts' do not appear under the 'Result Explorer' tab.
For the 'Concepts' filter to be available, a clustering report has to be generated which is a Engineering Data Science (EDS) feature.
If one has the required EDS license feature, the 'Concepts' would appear (as shown below) in the 'Result Explorer' tab.
Hence, upgrading the license with the required features is the only recommended solution for this issue.
Unless, you have the required EDS license & you are still having this issue. If that is the case, kindly let us know so that we can suggest accordingly thereafter.
Many thanks.
Kind Regards
Garima Singh
Hello @georgetrik ,
HyperWorks Desktop and Mechanical packages (both installed through Master installer) should be enough to access Generative Design.
Which version are tou using, and where in the process are you facing a stopper?
Best Regards,
Michael
