Overview: When you need to change a model that was working with Second order to First order, Rigid (RBE2)/RBE3 is not automatically updated to match the change in Order.
Therefore, if you run this script after the Order Change, the Rigid information will also be updated to match the changed Element Order.
Post-Requisite:
- Change to First order
- Run script(updated RBE2/3)
Release Version: 2024.1
