Overview: You can use it if you need to determine the center of each Solid and generate points.
In this script, you enter the name of the component in the GUI where the point to be created will be stored, and the solid's center point will be stored in the component with that name.
If the name already exists, it will be stored in the component with that name.
Post-Requisite:
- Enter a component name > Click ‘Create points’
- Select solid
- Create point and component
Release Version: 2024.1
