Hi!I am using Optistruct to conduct a transient NVH simulation, there's an error: "Not enough memory. (error code -2)". My run option is "in-core, -nt 18".
As you can see, the “.Out” file shows Estimated Memory (RAM) for In-Core Solution is 85002 MB and my computer has enough memory(248073 MB RAM) .
Could you please advise what should I do? Simplify my model or choose “-core(out/min)” run option? Thanks a lot!
