I am trying to generate a 15x15 rectangular patch array.
I have started by using the component library and specifying a frequency for a single element.
This single element runs. when I create a 4 x 4 array and change the properties of the substrate, change the Cuboid1 width (W) so that elements do not overlap, and run the structure it provides correct results.
when I try to generate larger structures 8x8 or larger i receive the following error:
"ERROR 31061: ADAPTFEKO run will terminate now due to error in RUNFEKO"
What does this mean? Is it a setup issue or a memory issue?
I am running this on the full program (not the student version) and I am using a server with 1TB of RAM and ample space on the harddrive.
