Overview: This script generates pressure after calculating the area of each element by entering the total load.
The total load can be expressed by selecting Force / Pressure.
You can use the surface/element/node buttons to display it anywhere you want.
Post-Requisite:
- Select the type of load you want to apply.
2. Enter the total load.
3. Select elements to apply the total load (elements included in the surface are also possible, and in the case of force, the load is applied based on the node.)
4. The total load entered is distributed and applied to each element.
(A new load collector is applied and a load entity is created. If the total load is 1000 and the number of elements selected is 4, the load per element will be 250).
Release Version: 2024.1
